OBDII to OBDI??
Old Aug 14, 2005 | 10:34 PM
Schweet97Z's Avatar
OBDII to OBDI??
what all is involved in converting from OBDII to OBDI? Very Interested in doing the conversion. Let me know the advantages and disadvantages.
Old Aug 14, 2005 | 10:44 PM
madwolf's Avatar
Re: OBDII to OBDI??
I have a part of your question covered here.
As for disadvantages, there is the "high stall" issue which some cars with stalls 2800 or higher may experience and you won't be able to pass the scan test for an emission check. (if needed) You can keep your OBD2 for that though.
Overall, OBD1 is better for performance.
Old Aug 15, 2005 | 07:15 AM
Schweet97Z's Avatar
Re: OBDII to OBDI??
now what do u mean w/ the stall? im probably going to go w/ a 3600 or 3800 stall. so OBDI is going to mess around w/ it? if so im just not going to worry about it. the reason i want to convert is because this guy i know tunes cars on the side. the guy is amazing at what he can do.
Old Aug 15, 2005 | 08:06 AM
1997Z4CSS's Avatar
Re: OBDII to OBDI??
OBD1 seems to have more tuners around then 2. I bought Madz's OBD1 tuned pcm for my stock setup last year. That combined with fresh plugs and injector cleaner through the gas and I was 20 RW more HP. . Great bang for the buck
Old Aug 15, 2005 | 10:03 AM
madwolf's Avatar
Re: OBDII to OBDI??
Yes, you will most likely have problems. I would stick with the OBD2.
Old Aug 15, 2005 | 06:14 PM
96capricemgr's Avatar
Re: OBDII to OBDI??
This is in no way a cut at Ion, I have used him for stuff and plan to use him again in the future.
That said some tuners can tune out the OBD1 high stall issue, talk to whomever you plan to use and see what he says.
Old Aug 15, 2005 | 06:19 PM
madwolf's Avatar
Re: OBDII to OBDI??
I have the same "high stall fix" other tuners use, but it doesn't work on all cars, that's why I recommended to stick with the OBD2 since it will work for sure.
96z
Mar 6, 2003 01:03 AM
96z
Mar 5, 2003 05:24 PM
madwolf
Feb 24, 2003 02:21 PM
SnkEatr
Feb 9, 2003 09:56 PM
96z
Feb 6, 2003 03:23 PM
