obd1 or obd2 aldl cable
Old May 16, 2013 | 09:43 PM
dzltek's Avatar
I have a 95, I know its got an obd2 connector, with an obd1 computer. My question is this, can I buy a regular obd2 cable to tune and datalog with or does it have to be a 'special' $80 cable made specifically for the 95?????? Ive looked at shoeboxes schematic, but I couldn't tell exactly the difference between the obd1 and 2 connectors.
Old May 16, 2013 | 10:18 PM
slick1hunting's Avatar
ALDL OBD1 OBD cable OBDI OBD2 engine codes also if you scroll down to fans turning on post there is a link to tunercats that includes software and the cable
Posted from Camaroz28.com App for Android
Old May 16, 2013 | 10:22 PM
Re: obd1 or obd2 aldl cable
Pretty sure that if the OBD-II cable would work, they wouldn't offer the other type of cable (that does work). You can also get one for less than $80. (example)
Old May 17, 2013 | 06:41 AM
dzltek's Avatar
I figured they were different, but I'm a cheap *** and if I can I will go the cheap route 75% of the time. But not this time. Thanks.
Old May 17, 2013 | 04:38 PM
Is this cheap enough:
Make an OBD1 cable for under $20 - Firebird Nation
Old May 17, 2013 | 09:26 PM
phonedawgz's Avatar
You can get an OBD1 aldl cable for $55.00 shipped at ALDL USB Cable
That's pretty much the lowest if you don't make it yourself.
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
whitehooptie
Aug 10, 2015 07:02 AM
