Obd1 dowloadable software??
Old Aug 29, 2024 | 11:12 AM
ledfootz28's Avatar
Trying to read code on 94 Z. Found my old connecting obd1 cable just need to know what software is everyone using these days that i can download on laptop??.
Old Aug 29, 2024 | 11:28 AM
Re: Obd1 dowloadable software??
Scan94/95:
https://www.camaroz28.com/forums/com...95-lt1-874306/
https://www.camaroz28.com/forums/com...-guide-886891/
Old Aug 29, 2024 | 01:36 PM
ledfootz28's Avatar
Thanks fred just downloaded program on laptop and noticed my old cable has a 9 pin serial port end. Of couse my newer laptop doesnt have this port so looking to get a new usb obd1 port cable now to run the scan.
Old Aug 29, 2024 | 01:44 PM
ledfootz28's Avatar
Fred does the obd1 store ses light codes. My light came on few seconds then stayed off a couple times driving now. Will i be able to still read whatever code it threw if light is currently off??
Old Aug 29, 2024 | 06:13 PM
Should remain in volatile memory until the vehicle has completed a specific number of “drive cycles” without the fault recurring. You can find more info about each code and what happens in the factory service manual. If you don’t have a factory service manual, free download here:
https://www.mediafire.com/?40mfgeoe4ctti
If battery backup power to the PCM is lost, even for a few seconds, volatile memory will be lost. Don't disconnect a battery cable, or pull the “PCM BAT” fuse.
Old Aug 29, 2024 | 07:27 PM
ledfootz28's Avatar
Ok thanks i ll order a cable asap and wont drive it hoping to pull code it threw. I ll keep thread updated once i find out more info
Old Sep 10, 2024 | 07:24 AM
BellaFoster's Avatar
I am just posting so I can keep track of this thread.
Old Sep 10, 2024 | 11:40 AM
Noticed you indicated "GB" in your profile, indicating you are in Great Britain, and also that your IP address is from Spain. Do you actually own a 93-95 LT1? If so, we always like to see photos
CrashnBurn
Parts Wanted
Mar 12, 2009 05:31 PM
JWS6
Sep 22, 2007 01:32 PM
joshp007
Dec 25, 2005 12:44 AM
jmanz28
Aug 24, 2005 04:31 PM
ollie-99
Parts Wanted
Oct 3, 2003 02:41 AM
