Obd1 dowloadable software??
Trying to read code on 94 Z. Found my old connecting obd1 cable just need to know what software is everyone using these days that i can download on laptop??.
Re: Obd1 dowloadable software??
Thanks fred just downloaded program on laptop and noticed my old cable has a 9 pin serial port end. Of couse my newer laptop doesnt have this port so looking to get a new usb obd1 port cable now to run the scan.
Fred does the obd1 store ses light codes. My light came on few seconds then stayed off a couple times driving now. Will i be able to still read whatever code it threw if light is currently off??
Should remain in volatile memory until the vehicle has completed a specific number of “drive cycles” without the fault recurring. You can find more info about each code and what happens in the factory service manual. If you don’t have a factory service manual, free download here:
https://www.mediafire.com/?40mfgeoe4ctti
If battery backup power to the PCM is lost, even for a few seconds, volatile memory will be lost. Don't disconnect a battery cable, or pull the “PCM BAT” fuse.
JWS6
Sep 22, 2007 01:32 PM
