OBD I - Can't read codes - No SES Flash
Old Jul 20, 2008 | 03:08 PM
snod83's Avatar
I have a 94 camaro z28 and I am trying to read the ses codes with an actron reader from advance auto. When I plug the reader in and turn on the key, the fans come on and the car acts like it should. It locks the shifter in place so it can't be driven and such. The problem is that the ses light doesn't flash at all. No code 12, no nothing. I checked the fuse for the cigar/horn and it is fine.
What do you think would cause this?
Thanks in advance,
Ryan
Old Jul 20, 2008 | 03:19 PM
You need a real scanner. You cannot flash codes on a 1994 LT1 f-body.
Old Jul 20, 2008 | 03:27 PM
markclrks's Avatar
sounds like u bought the 30$ scanner, wont work you need a scanner that can read out the pcm reading...if u buy one get the ones that can read both obd 1 and 2 anything after 96 has obd2 system
Old Jul 20, 2008 | 04:00 PM
snod83's Avatar
I am confused, the box says it will work on a 94? Why would they lie?
Old Jul 20, 2008 | 04:10 PM
moparman's Avatar
Unfortunately, it won't work. '93 is the last year for shorting the pins. As was said, you need a real code reader or scan tool. If you still have the receipt, take it back.
Old Jul 20, 2008 | 04:42 PM
They are misinformed.
Old Jul 21, 2008 | 05:32 AM
Because they don't know what they are talking about. Trust us.... IT WILL NOT SCAN YOUR 1994 PCM. Take it back and get your money back.
aj2494
Mar 12, 2015 10:17 PM
Jul 4, 2005 05:00 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
