OBD Code Question
Old Sep 7, 2010 | 04:12 PM
eball218's Avatar
OBD Code Question
Ok so my car is trowing codes 26 and 27. I looked on shbox.com and have seen that these are
26 - Evaporative Emission (EVAP) canister purge solenoid valve circuit
27 - Exhaust Gas Recirculation (EGR) vacuum control signal solenoid valve circuit
My questions are this. First will these codes that Car to be put into "Limp Home Mode" and second where would i begin to look to fix these problems? Any help would be great. Thanks in advance.
Old Sep 7, 2010 | 04:27 PM
n2ceptor's Avatar
http://www.troublecodes.net/GM/94_57P.shtml
Old Sep 7, 2010 | 04:39 PM
eball218's Avatar
I have looked this up and i see that both 26 and 27 have to do with emissions parts. Which my car does not have. How would i program these out of the pcm i have the cable and a laptop.
Old Sep 7, 2010 | 05:07 PM
You need to turn off the code reporting in the switch table. I'm curious why you asked for troubleshooting advice when you have the items removed.
Old Sep 7, 2010 | 05:37 PM
eball218's Avatar
Thanks Bought the car this way.
Old Sep 7, 2010 | 11:15 PM
Originally Posted by n2ceptor
While that code list is labeled "94", its clearly for a 93, not a 94. There are no "quad drivers" on a 94. 93 was last year.
You really need to use Shoebox's guide, which identifies the differences between 93 and 94/95:
http://shbox.com/1/Dtcs.htm
HectorM52
Jul 30, 2017 11:46 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
91Bird305
Aug 5, 2002 01:39 PM
