obd code
Old Sep 18, 2012 | 09:49 PM
stenlt1's Avatar
obd code
got a code 23 intake manifold temp low changed sensor cleared code still their checked voltage at pigtail got 5 volts what else can i do to fix it or can something set it off?
Old Sep 19, 2012 | 04:37 AM
RamAir95TA's Avatar
Re: obd code
Most likely something in the wiring then.
Old Sep 19, 2012 | 05:15 AM
Re: obd code
Test the sensor using this, courtesy of Shoebox:
4th Gen LT1 F-body Tech Articles
While testing the harness wire, make sure you twist and jiggle it to identify an intermittent condition.
cmdeshon
Jan 4, 2015 11:15 AM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
