o2 sims question
Old Apr 27, 2004 | 09:26 AM
warbird27's Avatar
o2 sims question
i went to order my o2 sims from summit just now, and i dont know which one i need, the 97-2001 or the 95-96 one. i called and they couldnt give me an answer and they said to check if it was a 4 point. i went under and it is hard to get to and i dont have the time really to pull things to get to it to see. i was hoping someone had a quick answer. i figured 97 would be different than the ls1's.
Old Apr 27, 2004 | 10:02 AM
Red96Lt1's Avatar
Why not just get a tune and have them programed out for $125 from madz28 and gain some power in the process?
Old Apr 27, 2004 | 10:45 AM
warbird27's Avatar
then do i just block off the o2 bungs and leave the sensors unplugged
Old Apr 28, 2004 | 08:47 AM
EviLBoX's Avatar
Yep. You are removing the rear O2 sensors right? ... because you need front O2 sensors.
Old Apr 28, 2004 | 08:50 AM
LSUxBlake's Avatar
You don't need to block off anything, just leave the 02's in there. And yes, I hope you're talking about the rear.
Old Apr 28, 2004 | 08:56 AM
AStockerifficZ's Avatar
From: Born in Chicago IL, Grew up in Aurora IL, Stationed in Jacksonville FL.
all the O2s are 4-point, its the design of the plug that matters, fronts are flat-4 the rears are square-4. Ive got a set of sims that i dont need because i did an OBD2-OBD1 conversion and had the rears removed, they have been on the car for i think 7 months, they still work perfect they are just a little dirty. $75 bucks, they were $125 brand new.
jasonduaine
Mar 7, 2015 09:44 AM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
timmat1
Jun 29, 2003 09:29 AM
