heater bypass quick question.
Old Apr 26, 2004 | 12:31 PM
QCKZ28's Avatar
im removing my HVAC system, all i need to do for the heater bypass is connect my heater hoses coming from the water pump right? both of the heater hoses are on the pass side....
will this cause any problems? will it over heat?
thanks
jesse
Old Apr 26, 2004 | 12:35 PM
HBHRacing's Avatar
if your just linking the 2 heater hoses that go into the firewall then all you are doing is taking the heater core out of the loop. it will be fine. just make sure you bleed the system correctly when your done
Old Apr 26, 2004 | 01:28 PM
Mtrhds94Z's Avatar
Jesse, one hose is 5/8" and one is 3/4".. so you might get a 5/8 x 3/4 coupling[reducer] so the hoses fit right, then use a piece of each size hose from the coupling to the WP..
Old Apr 26, 2004 | 02:52 PM
QCKZ28's Avatar
thats exactly what i did
how thick does plate that blocks the big hole in the firewall have to be for NHRA?
thanks for the info,
jesse
Old Apr 28, 2004 | 09:38 AM
QCKZ28's Avatar
68camaroboltz
Oct 5, 2015 11:56 PM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
Fatdog2
Sep 16, 2015 11:04 PM
NewsBot
Sep 14, 2015 09:20 AM
