o2 sensors question
Old Jul 13, 2006 | 08:13 PM
gillt1's Avatar
Question o2 sensors question
Hi Guys, on a 1996 z28 there seems to be 3 , O2 sensors ,2 with flat four connector ,1 with square connector,if I install lt pacesetters,can I delete sensor with square four connector,or do I still need it ,I know my sig says 1995 but I purchased another z28,Thanks for any insight.
Old Jul 13, 2006 | 09:05 PM
2000GTP's Avatar
Re: o2 sensors question
You actually have a total of 4 sensors, two pre-cat sensors and two post-cat sensors. Its the two post-cat sensors in which you will use the 02 simulators on.
Old Jul 14, 2006 | 06:13 AM
gillt1's Avatar
Thanks 2000GtP,what are 02 simulators and where would I be able to buy a set of 02 simulators ? Again Thanks for any help
Old Jul 14, 2006 | 03:57 PM
2000GTP's Avatar
Basically, once you run the long tube headers, you will not be able to use your stock y-pipe, you will have to use the off-road y-pipe which will not have catalytic converters. The rear 02 sensors are simply there to monitor the catalytic converters efficiency. By the converters not being there no more and by having an off-road y-pipe with no 02 bungs, you will need to eliminate the rear 02 sensors and by doing so, you will get an SES light. In order to avoid the SES light, you will need the 02 simulators which will simply plug into the ends of the rear 02 harness connectors and provide a "dummy" signal to the PCM that the catalytic converters are there and in working order. You can get a pair of 02 simulators from Thunder Racing and they run about 90 dollars for the pair.
Old Jul 14, 2006 | 04:01 PM
The rear, square plug O2s are the ones you swap for the sims.
Old Jul 14, 2006 | 05:10 PM
SSmoknLT1's Avatar
What do you do with the front o2's ?
Old Jul 14, 2006 | 06:36 PM
You use them as they are intended to be. You don't simulate them. Their input is needed for fuel delivery calculations.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
