O2 sensor question
Old Mar 12, 2010 | 04:27 PM
BCook839's Avatar
O2 sensor question
My Bank 2 upstream O2 sensor went out. Who here would just replace the one sensor, or replace both of the upstream sensors on the car? I ask because I didnt know whether or not to be concerned with how the new sensor's readings would compare with the old one on the other bank. Will it effect the feul trim levels from bank to bank and cause drivebility problems?
The sensors are only 53 bucks a peice at my local parts store. I'm tempted to replace both.
Old Mar 12, 2010 | 04:32 PM
RamAir95TA's Avatar
As a maintenance procedure, it definitely wouldn't hurt to replace both. Make sure you use AC Delco sensors though...lots of people have reported issues with other brands.
Old Mar 12, 2010 | 04:37 PM
Guest47904's Avatar
Guest
AC and GM's are made by Standard. If your auto parts store doesn't have either of the 3, move on till you find them.
Old Mar 12, 2010 | 05:14 PM
Did you determine that the O2 sensor "went out" from a code scan? If so, give us the exact code. Some O2 sensor codes are caused by problems other than the O2 sensors themselves.
Old Mar 16, 2010 | 12:53 PM
BCook839's Avatar
I cant remember the code's exact number but it was a P015X. It's title was: Bank 2 Sensor 1 Heater circuit malfunction. I checked the pid levels coming from the sensor in the data stream fuction of my buddies MAC Tools scan tool. The wave, though not too detailed on the little bitty screen, was virtually identical to the wave coming from the other O2 sensor on the Bank 1. And feul trim levels were good. So im thinking that it really is just the heater circuit, and the sensor is reading fine once it does finally get up to temp.
I checked with my local IWI parts store, and they carry the AC Delco sensors for 90 bucks a peice. I think i might just go with the one sensor for now.
Old Mar 16, 2010 | 01:28 PM
Have you checked the wiring to insure you have 12V (brown wire) and a ground (black wire) at the harness connector?
Old Mar 16, 2010 | 02:23 PM
StangCrusher350's Avatar
bro, you can get the acdelcos from their site for 69.99 a piece.
Old Mar 17, 2010 | 04:14 PM
BCook839's Avatar
Injuneer, I have not had a chance to crawl under the car yet to do so but I sure will before I go buy the sensor.
I figure it is worth saying, this is why i jumped on it deffinatly being the O2 sensor being faulty; The header colector that this O2 sensor is connected to, was leaking terribly and i drove the car a couple times with this problem before i was able to fix it with a better type of clamp. I think this is why the sensor is screwed up, as I have heard other people complain that O2's can be fouled out by running open headers or a bad exhaust leak.
Thanks for the tip StangCrusher350, I will check out their site.
Old Mar 17, 2010 | 09:44 PM
The O2 sensors are not "fouled out" by being in an open collector, or being downstream from an exhaust leak. Those problems cause the sensor to read inaccurately, because of the air mixed into the exhaust gasses. The sensor isn't "fouled", its "fooled". No physical damage is done, and eliminating the source of outside air will return the sensor readings to the correct values.
Additionally, excess cool air being added to the exhaust can slow down the sensor heat up. The heater circuit check is based on the PCM measuring the time required from a cold start for the sensor to start being active - an indication that it has reached the minimum temperature required for it to operate. The PCM infers that if the sensor is not heating up fast enough, there is something wrong with the heater.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
