O2 Sensor Extensions?
Old Feb 26, 2006 | 08:41 PM
  #16
LagunaS3's Avatar
Re: O2 Sensor Extensions?
Ok, I will probably still splice myself. So you guys think with LT's and O2's in the collector 12" will be enough?
Zach
Old Feb 26, 2006 | 08:53 PM
  #17
revtime's Avatar
Should be fine.
Mine were about 12 inches and they reside in the pipe AFTER the collector.
Old Feb 27, 2006 | 12:10 AM
  #18
1quickTA's Avatar
Those wires dont really solder well. I knew they wouldnt take the solder for me when I tried, and then I read some reason why later. I ended up crimping mine and have had no noticable issues at all.
Old Feb 27, 2006 | 05:01 AM
  #19
LagunaS3's Avatar
Maybe I'll just do the old fashioned way...twist them together and put some electrical tape over the bare wires and call it done!!!
Old Feb 27, 2006 | 05:25 AM
  #20
Guest47904's Avatar
Guest
I fail to understand why anyone would do any splicing when you can get these
http://store.summitracing.com/defaul...=egnsearch.asp
cheap enough. Let alone a "twist" and tape
Second, our O2s get their oxygen supply through the back at the wire openings. NEVER make splices between the O2 and it's connector.
Old Feb 27, 2006 | 05:47 PM
  #21
LagunaS3's Avatar
Extensions at the site above are 21.95 each. With the 8.95 "handling" charge it comes to a grand total of $52.85. That's absolutely ridiculous for $2.75 worth of wire and $4.25 worth of plastic. If they are gonna charge that, they could at least include some vaseline.
Zach
Old Feb 27, 2006 | 06:28 PM
  #22
T/A Racer's Avatar
i agree on that, just spliced mine for my pacesetters last night. although i made 2 mistakes, #1 not checking the values before and after the extension, although i didnt have much of a choice due to a new engine going in, and #2 not realizing that 2 wires are the same color till after i cut . anyways im pretty sure i got it right, although i do think one of my o2 sensors is bad because its values are barely fluctuating on the scanner.
o and i measured with a tape then made my own, had the o2s in the collectors, came out to about 18" on shorts side, and 24" on driverside. i measured long though so i didnt have to make new ones if they were too short.
Old Feb 27, 2006 | 10:35 PM
  #23
revtime's Avatar
I wanted to try it and see if it would work.
Everyone said don,t splice the O2 wires themselves it will ruin them. I just had to see for myself. I did spend some time on them and did it all right, and they have worked fine. Readings are fine and the car ran 4 tenths faster and 3 MPH more after the header install so I,m gonna go out on a limb and say they are working fine.
Old Feb 28, 2006 | 05:10 AM
  #24
LagunaS3's Avatar
Ok, well after all my whining I got a line on a cheap set of O2 extensions. They are $35 shipped for a pair of 12". So, I think I'm gonna go ahead and get them. But, does anything thing 12" won't be long enough?
Zach
Old Feb 28, 2006 | 07:48 PM
  #25
LagunaS3's Avatar
Everyone think 12" is enough?
Zach
Old Mar 1, 2006 | 10:08 AM
  #26
MeanGreen97Z's Avatar
Zach
I dont know.... save that question for her. LOL
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
zajones
Jul 30, 2015 02:18 PM
