O2 Sensor Extensions?
Old Feb 25, 2006 | 08:31 PM
LagunaS3's Avatar
Instead of buying O2 sensor extensions is there anything wrong with just splicing wire to the sensors, if done correctly? I just have a hard time paying $42 from summit for 2 extensions...it's just wire and plastic.
Zach
Old Feb 25, 2006 | 08:35 PM
LT1 POWR's Avatar
Re: O2 Sensor Extensions?
If you know what you are doing that is fine. Just make sure you do one wire at a time. I think 2 of the wires are brown and you dont want to mix up the wires.
Old Feb 25, 2006 | 08:36 PM
LagunaS3's Avatar
Well, I just figure same gauge wire, soldier, and heat shrink. Anything I missed?
Zach
Old Feb 25, 2006 | 09:43 PM
LT1 POWR's Avatar
I crimped mine cuz my soldering iron sucks. But yeah soldering would be better.
Old Feb 26, 2006 | 12:21 AM
94 BIGRED's Avatar
Also use the same kind of wire. Don't make them to long because ur going to change the resistance and us solder
Old Feb 26, 2006 | 02:24 PM
2000GTP's Avatar
If you are going to modify your own, I would definitely try to solder them if possible and then put some heat shrink tubing over the splice.
Old Feb 26, 2006 | 02:53 PM
96ZCamaro's Avatar
I payed about $30 for my 12'' o2 extensions at http://www.redlineperformanceenginee...om/lt1main.htm and definatly think it will be worth the money. And its just a little insurance from doing it yourself incase somthing isnt the same with the wireing you would be doing yourself.
Old Feb 26, 2006 | 03:26 PM
Projectz28's Avatar
Moderator
If your skilled enough to splice, soldier, and heat shrink... then there is absolutely nothing wrong with it. Just dont do what I did. I did all that and didnt actually measure how much I needed first. Long story short I later installed the headers and went to plug em in and I still ended up 1/2" short
Old Feb 26, 2006 | 03:29 PM
FastZinTennessee's Avatar
I extended my last O2 harness when I had SLP headers, but with the new long tubes I bought a pair of extensions. There's nothing wrong with doing it yourself and saving a few bucks.
Old Feb 26, 2006 | 03:48 PM
2000GTP's Avatar
Yeah, same here, I got a pair from www.ls1speed.com for around 30 bucks. Peace of mind and the ease of just plugging them in made up for the small cost.
Old Feb 26, 2006 | 05:09 PM
LagunaS3's Avatar
Yeah, I don't exactly know how long I will need. I am switching to LT's with the O2 bung in the collector. I figured I'd do 24" just to be safe...
I just have a REAL hard time paying that much money for a couple pieces of plastic and wire. If they were worth it, that'd be different...but cost on those can't be over $20 per pair.
Zach
Old Feb 26, 2006 | 05:35 PM
2000GTP's Avatar
Zach
I originally had the 24" extensions to be safe and they ended up being excessively long, so I took them back and got a pair of 12" and they worked fine.
Old Feb 26, 2006 | 06:05 PM
turbo_Z's Avatar
Yeah go with www.ls1speed.com extension. They work perfect but like has been said.. go with the 12" and next length down or youll have them hanging everywhere. I have Hooker LTs and I wish I had gone the size under 12".
Old Feb 26, 2006 | 07:50 PM
Projectz28's Avatar
Moderator
I gotta belive the total cost on a set of extensions is under $5....
Old Feb 26, 2006 | 08:36 PM
revtime's Avatar
I spliced wire into the O2 sensors themselves, I was not going to hack into the harness.
I crimped them just to see if it would work and I have had no problems since I did it, about 26k ago.
I watched the O2 counts on my scanner and they look the same before and after.
