How to clearance timing cover???
Old Mar 1, 2006 | 08:31 AM
ssnorm96's Avatar
I am going to a Cloyes Double roller, and an EWP, just need to know how/where to clearance the timing cover? I have also read, that with an OBD1 conversion, the CPS is not required, but the reluctor ring is in order to seat the gear, and correctly space the hub...does the reluctor require modification as well? What's the recipe for success here??? Thanks all.
Old Mar 1, 2006 | 08:47 AM
Javier97Z28's Avatar
Moderator
Re: How to clearance timing cover???
Here's one we did recently:
http://www.mattz28.com/Caminstall/Pics/DSC01015.jpg
That should give a general idea.
The reluctor ring should come out and you should use a 93-95 hub if it was in an F-body, not sure about the impala cars, may be a similar situation for you guys. The 96/97 hubs were shorter due to the reluctor ring being in there.
Old Mar 1, 2006 | 09:05 AM
ibanez6rg's Avatar
When we did my install, atljar put white grease on the timing chain, put the cover on with a few bolts, turned the motor, and where ever there was grease on the timing cover we grinded down and checked again.
Old Mar 1, 2006 | 10:55 AM
jsetzer's Avatar
Thats how I did it, needed very little work to take care of it. More cleaning up casting rough spots than really taking meat off.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
