O2 Sensor Code
Old Nov 18, 2006 | 09:05 PM
LT1_King's Avatar
O2 Sensor Code
my car is throwing this code causing my car to run very rich. i had cut off the stock cat because it was clogged and it started running like this. so then i put a high flow cat from a camaro the same year. it still throwing the code and still running rich. how would i decode this problem or is there a certain technique to get rid of it? my car is a 1994 A4 Z28.
Old Nov 18, 2006 | 10:47 PM
Sweetred95ta's Avatar
What code specifically? Did you cut the cat off and run an open exhaust? Do you have a log of the car?
Old Nov 19, 2006 | 09:58 PM
There are 6 different O2 sensor codes for your OBD-I 94. Knowing which code you have will make it easier to diagnose it and suggest a fix. There is no relationship between cutting the cat off and an O2 code in an OBD-I car.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
Aug 5, 2002 01:39 PM
Fusion93Z
Jul 29, 2002 06:13 PM
