O2 questions
Old Jun 3, 2003 | 05:45 AM
Chewbacca's Avatar
O2 questions
Can I replace just the front two sensors?
The rears don't need to be replaced 'cause they only keep an eye on what the converters are doing, correct? Am I also correct in that the PCM uses only the front O2 sensors for its calculations?
The car is running pig rich and I figure its a pretty good bet that the original 94,000 mile sensors are shot. No sense in replacing the rear sensors if there is nothing to be gained.
Is the correct P/N for the sensors 25312184? If I do have to change the rears they use the same P/N right?
Old Jun 3, 2003 | 05:57 AM
Yes, you can just change the fronts. Yes, only the front sensors are used to feed back the A/F ratio info so the PCM can make corrections.
I believe the connectors are a different shape on the pre-cat and after-cat sensors, so the part numbers are probably different.
Old Jun 3, 2003 | 08:16 AM
Hyperspeed97z28's Avatar
before the cat are FLAT PIN connectors and after the car are SQUARE PIN connectors... Now if I can just find my damn O2 SIM on the drivers side...
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
