O2 extensions on 95 Bird
Old Oct 23, 2006 | 08:37 AM
Walkersteelhead's Avatar
I'm getting long tubes soon will I need O2 extensions. It is a 1 cat car. Sorry if this had been beaten to death I just couldn't find a definitive answer.
Old Oct 23, 2006 | 10:18 AM
MysticTeal95Z28's Avatar
Re: O2 extensions on 95 Bird
I'd like to know this too, I'm working on getting longtubes on my car currently. It's up on jack stands with a couple of bolts out of the manifolds right now. I'm taking my time on it, haha.
Old Oct 23, 2006 | 10:26 AM
Javier97Z28's Avatar
Moderator
Yes, you will need O2 extensions.
Old Oct 23, 2006 | 10:40 AM
For driver side and passenger side both? I saw that you had two on your car, I'm just making 100 % sure since you have a '97 and I have a '95.
Old Oct 23, 2006 | 11:18 AM
95LT1conv's Avatar
you could probably get by with 1 on the passenger side. i used both during my install, but i had to wrap the driver side extension around the clutch hyd. line about 3 times to take up the slack. if ya need 1 look on ebay. i got mine there for $16. anywhere else i looked they were $25
Old Oct 23, 2006 | 11:27 AM
Moderator
I'd get two.. you never know if your harness may be a little shorter than someone else's.
The front O2's on all the LT1's are in the same place, doesn't matter whether it's a 95 or a 97.
Old Oct 23, 2006 | 11:31 AM
OK, thanks man. Your car is bad-*** by the way.
Old Oct 23, 2006 | 11:39 AM
Moderator
thx
Old Oct 23, 2006 | 01:24 PM
2000GTP's Avatar
I would go with two, one for each side. The passenger side definitely needs one, the drivers side can make it without one, but you are really stretching the harness and that prevents you from routing the harness away from "trouble spots" due to the lack of play. A couple of 12" extensions should do the trick.
Formula Steve
Sep 19, 2023 08:31 AM
Victor Lamb
Aug 26, 2017 02:52 PM
2QUIK6
Sep 17, 2016 02:31 PM
Jlo
Jun 24, 2015 11:54 AM
joink
Sep 19, 2001 03:16 PM
