Not getting a charge
Old Nov 15, 2005 | 01:24 AM
XChris1632X's Avatar
most of the bugs of my motor swap is worked out. i thought i had a dead alt. so i swaped it with with a 2 month old one out of our other lt1. basically i am not getting any charge out of the alt. zero. my lights and car runs until the battery dies. its just not charging. none of the guages work. the lights work. also the ses light and all of the other lights never come on. only the security light comes on before startup. i moved the main ground around and have it bolted currently to the bellhousing and everything is working fine. i dont know where to even start.
Old Nov 15, 2005 | 09:21 AM
BUBBA's Avatar
Re: Not getting a charge
Battery?
Old Nov 15, 2005 | 10:02 AM
EKO's Avatar
EKO
Dumb question, but are you sure you connected the positive lead from the battery to the alternator? I almost forgot to do it when I swapped mine.
Old Nov 15, 2005 | 01:31 PM
battery is good. and so is the wire to the alt
Old Nov 16, 2005 | 12:54 AM
no one?
Old Nov 16, 2005 | 03:20 AM
ok nevermind i got-er-done. it was a short to ground that was blowing my guage fuse. after i moved the ground i never checked the fuse again and without that fuse the alt will not charge.
RUENUF
Mar 13, 2016 03:37 PM
68camaroboltz
Oct 5, 2015 01:46 PM
cmsmith
Sep 14, 2015 09:25 PM
WPHIG2
Aug 27, 2015 06:37 AM
Boss002
Jul 24, 2015 10:47 AM
