6" rod, .030 overbore on stock LT1
Old Nov 15, 2005 | 05:44 PM
Hybrid86Z's Avatar
anyone know what "ballpark" would the cubic inches would be on something like this? Crank will be stock stroke.
I am looking to build a nice budget fully forged bottom end, using a 6" forged I-beam connecting rod and have the walls bored .030 w/ forged SRP pistons, and an Eagle forged crank.
I will be looking at low compression, around 9:1 or so, and run 12-15 psi of intercooled boost.
would the eagle forged crank be overkill? cost-effective to go cast for the crank or no?
I'm hoping for 550rwhp give or take.
thanks for the help guys
-Ben
Old Nov 15, 2005 | 05:58 PM
rskrause's Avatar
Moderator
Re: 6" rod, .030 overbore on stock LT1
Rod length has nothing to do with displacement. A 30 over 350 is ~355ci.
Rich
Old Nov 15, 2005 | 06:01 PM
Hybrid86Z's Avatar
ok thanks Rich.
would it be worth going w/ the 6" rod over the 5.7"?
Old Nov 15, 2005 | 06:10 PM
rskrause's Avatar
Moderator
Not much difference. If you do a search, you can see a lot of opinions and decide which one makes sense to you.
Rich
Old Nov 15, 2005 | 06:19 PM
Hybrid86Z's Avatar
yup, i've been reading a few threads
Old Nov 15, 2005 | 10:46 PM
mebanditws6's Avatar
For a blown application there's not much benefit. But if you were to go N/A with big heads and a solid lift cam where you'd be spinning to 8000, the longer rods would be of benefit due to less sideloads and friction on the cylinder walls.
Jason
Old Nov 16, 2005 | 05:13 AM
LameRandomName's Avatar
Originally Posted by Hybrid86Z
ok thanks Rich.
You didn't ask me, but if you had I would say that it's not worth doing on it's own, but if you're rebuilding anyway, then you may as well go with the 6" rods.
oldschool
Feb 9, 2016 09:21 PM
Catmaigne
Dec 25, 2014 12:16 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
