Is it normal for the temp to fluctuate between the low and high fan turn on points?
Old Feb 1, 2008 | 08:54 AM
ssbowtie1's Avatar
My car has stock programming and I have a 180 thermo. When I'm moving, there's plenty of airflow and the car always runs fairly cool. However if I just let the car idle, the temps will rise up to ~230, the high fans will come on and the car will cool fairly quickly to approximately ~210, then that cycle will slowly repeat until I start moving again.
I know stock programming has the high fans turning on in that range, but my question is if it is normal for the temps to just fluctuate between ~230 and ~210 while the car is idling.
Old Feb 1, 2008 | 09:55 AM
rskrause's Avatar
Moderator
Normal.
Rich
Old Feb 1, 2008 | 11:23 AM
Originally Posted by rskrause
Normal.
Rich
Exactly. Any car with electric fans does this. Think about it. When you stop moving there is no longer any air flow. No air flow, engine heats up. The fans come on, there is air flow again. Engine cools down.
HCz28
Feb 15, 2015 03:01 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
