No volts to Mass Air
Old Jun 24, 2011 | 01:14 PM
  #16
LT1Jeepin's Avatar
Re: No volts to Mass Air
I believe he means Key On Engine Off.
Old Jun 25, 2011 | 10:00 AM
  #17
GRIDERMAN87's Avatar
ok, ill look that over is there a common fail point if there is not 5 v to the yellow?
Old Jun 29, 2011 | 03:31 PM
  #18
ok have 5 v to siganl wire with engine of,f no change when it starts still throws po100 at startup
Old Jun 29, 2011 | 10:46 PM
  #19
The voltage will typically drop to less than 5V when the engine starts.
Does your meter have a frequency scale? If so, hook the frequency meter up across the yellow and black/white wires, and look for ~2,800Hz at idle. The DC voltage is just there to serve as a carrier for the frequency, which is what the PCM looks at to determine the air flow.
DirtyDaveW
Dec 1, 2016 05:37 PM
mightymouse383
Jul 20, 2016 07:34 AM
oldschool
Feb 9, 2016 09:21 PM
Fatdog2
Feb 13, 2015 08:19 PM
