No Spark, VATS problem?
Old Feb 10, 2005 | 02:51 PM
  #16
m0nk's Avatar
Re: No Spark, VATS problem?
Well dont I feel dumb A + D check out fine. But B shoots up to 100mV and then drops to in the 90s, then just fluctuats in the 90's but not to wildly.
Going to check the opit and related wiring right now. Would a bad opti cause the BCM not to provide ground to the theft deturrant relay and not let the car turn over?
Old Feb 10, 2005 | 02:55 PM
  #17
1stz28's Avatar
I am a bit confused. Engine would not crank...removed battery and reinstalled 48 hours later...bypassed unknown relay...now car won't start. I guess I would have to agree with the post that suggested returning to the basics, like why won't it even turn over without bypassing relays. I personally would address the no crank problem first and then the no start problem.
Old Feb 10, 2005 | 03:17 PM
  #18
m0nk's Avatar
I belive they are related. The car will not crank because I am not getting the ground from the BCM to the Theft deturrant relay. I was hoping that its just a wiring problem or some corosion somwhere rather than a burntout BCM. The day i started having problems the temp dropped to 10 with -15 windchill.
Old Feb 10, 2005 | 03:25 PM
  #19
1stz28's Avatar
Sounds like you are on the right track. It sounded like you were getting a little bit ahead of yourself at first but I probably just misunderstood. Sorry I can't offer more help but I'm sure if you listen to some of the old timers on this board they will get you going again. Good luck.
Heathen1
Jan 2, 2016 04:27 PM
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
Lakebratt
Feb 5, 2015 07:55 PM
Jazsun
Dec 29, 2014 12:14 PM
