No spark. Help.
No spark. Help.
Ok still working on the 94 lt1 swap into a friends 91. We have the engine turning over. We have vatts deleted out of the pcm via tuner cats. We have the thedt deturent relay bypassed. Now the plugs are reviving no spark I also cannot hear the injectors plusing. Im fixing to go outside and use shoebox's write up to test if the signial from the opti is reaching the coil. I will report back with my findings.
The oil pressure sensor isnt hooked us as we broke the old one and havent installed the new one. Will this kill the spark? I mean if the computer doesnt see any signal from the oil pressure sensor will it cut the spark?
Give me some other things to check. i have checked the opti harness and i have checked the wiring to the pcm and all is fine. We wired this one up the same way we did the last one. Its in my wiring wrie up in my sig.
thanks in advance guys.
Ok just got back from using shoebox's how to to check the icm for signal form the opti and the signal form the ecm/
the meter was set on Vdc200
When i checked voltage on pins a and d i got the same .005 reading.
When switched over to Vac200 The reading on pin b was 1.45
Im completely lost and cannot figure out why this car isnt getting spark.
Fred, its not throwing a code. And yes the engine is turning via the starter and there is no spark. I checked the opti harness and the connectios at the pcm for corrosion. I also checked all the grounds and every fuse and everything is fine.
Benji, the injectors are not getting voltage either. Tested it with a noid light.
Formula Steve
Sep 19, 2023 08:31 AM
surreybrad
Sep 29, 2015 09:00 PM
