383 what lbs fuel injectors?
Old Nov 6, 2006 | 11:44 AM
kline454's Avatar
Im putting together a 383 with cc306 and ported heads 2.02-1.60, 11-1C.R and all the other mods in my mod list. Im not sure what lbs injectors i should use? I might put a 100-150 wet shot on it, I was thinking about the svo 30lbs or accel 32lbs?
Old Nov 6, 2006 | 11:53 AM
BlueCamaroZ28's Avatar
I am using 30# SVO's in my 383 stock headed LT1. 36 or 42 will give you room to grow but 30# SVO's are just fine with me.
Old Nov 6, 2006 | 12:02 PM
kline454's Avatar
ok thanks are the accel a good injector?
Old Nov 6, 2006 | 12:24 PM
2000GTP's Avatar
Alot of bad feedback regarding the Accels, I would stick with the SVOs as mentioned above.
Old Nov 6, 2006 | 01:05 PM
For ballpark sizing, multiply your flywheel HP x 0.07....
example: 500 flywheel HP x 0.07 = 35 #/HR
That assumes a decent tune (0.476 BSFC) and an 85% duty cycle. With 30# injectors, you are limiting yourself to about 450 flywheelHP, even allowing for the 5% extra flow you get out of the SVO's at 43.5psi. I'd opt for a 36# or even a 42# injector.
Old Nov 6, 2006 | 05:15 PM
kline454's Avatar
ok thanks that what i want to know.
AdsoYo
May 2, 2018 03:21 AM
MyfateZ28
Jun 19, 2015 03:42 AM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Jul 4, 2005 05:00 PM
SC97TA
Sep 15, 2002 01:10 AM
