No oil pressure after 2 yr resurection
Old Apr 3, 2005 | 03:47 PM
rambo benson's Avatar
My 94 LT1 vert blew the tranny nearly 2 years ago and has sat under a car cover ever since. I had a friend come over and pull the tranny, rebuild it, and re-install it. After that was finished, we fired the car to run through the gears. About 15-20 seconds at idle, I realized that I had no oil pressure. The needle barely moves (~1-1.5 psi) even will a very light (~1200) blip of the throttle. We checked the oil and it was dark and a little low and plan on changing the oil in a few minutes. I pulled the coil and disconnected the fuel pump to prime the oil pump but that didn't help either. Anybody have any suggestions?
Old Apr 3, 2005 | 03:51 PM
Hyperspeed97z28's Avatar
Re: No oil pressure after 2 yr resurection
maybe u wacked the sending unit while working with the tranny ?
Old Apr 3, 2005 | 04:55 PM
Yep. I found that shortly after posting. Any ticks to remove that? I have the Autozone socket.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
