What size bolts hold on the metal plug wire separator on the passenger side 97 Z?
Old Apr 2, 2005 | 05:22 PM
remaxracer45's Avatar
Putting my 97Z back together after many months of being apart trying to find out what size bolts hold that metal piece to the block that has the factory plug wire separators for the passenger side one is bigger than the other and the little one is by the motor mount. Thanks for the help
Shawn
Old Apr 3, 2005 | 05:18 PM
5.7LT1Formula's Avatar
Re: What size bolts hold on the metal plug wire separator on the passenger side 97 Z?
i left mine off. helps clean things up underneath alittle bit. i used some heat tape and zip ties to re position my wires. I'm not thinking about doing an Over the valve cover install.
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
Wilson
Jul 21, 2002 05:08 PM
