No oil pressure!!!
Old May 14, 2011 | 06:40 PM
drennon1's Avatar
No oil pressure!!!
Just finished my motor swap with a used engine. Start the engine oil pressure hits 40 then falls to 0. I checked the lifters and they are dry. I didn't replace the pump on the engine because I primed the engine before I put it back together and it seemed fine
Should I replace the pump? Anything I can check first? I also put a new oil pressure sender on before I installed the engine and deleted the oil cooler. Thanks
Old May 15, 2011 | 09:37 AM
ENRKyle20's Avatar
Re: No oil pressure!!!
I would use a mechanical gauge to be positive before you pull anything apart. It usually take a few seconds to pump the lifters up and a bit more to get oil up top (and some rpm for my engine).
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
