No oil pressure
Old Aug 10, 2004 | 08:45 AM
94zrag's Avatar
No oil pressure
I'm trying to pre-lube my motor by cranking the starter, but i'm not getting a reading on my oil pressure gauge. i should be getting at least a low reading or something, shouldn't I?
Old Aug 10, 2004 | 09:21 AM
Re: No oil pressure
Eventually, yes. I suppose you do have all the oil pump drive parts in place. I prefer to use a mechanical pre-oiler than the starter.
Old Aug 10, 2004 | 09:34 AM
94zrag's Avatar
Re: No oil pressure
How long would you recomend cranking the motor for? I did it 4 times for about 4-5 seconds each time. And yes, everything is in place, and all new parts.
Old Aug 10, 2004 | 09:39 AM
95RagtopTA's Avatar
Re: No oil pressure
I had the same problem--turned out that I was not allowing the starter to turn over long enough. Crank it for 5 to 10 seconds and you shoud see pressure (close to 20). Make sure you have the coil unplugged and the 2 fuel injector fuses removed.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
