No ignition feed to PCM? Wiring gurus inside!
Old Jun 8, 2006 | 08:53 PM
  #31
regorih inHous.'s Avatar
Re: No ignition feed to PCM? Wiring gurus inside!
I did the same thing, I put a 95 LT1 with the 95 wireing harness into a 96 and it would not turn on at all. The problem is that the 96 and 95 harnesses are two different animals, your going to have to use the 96 harness with your 93 motor. What I did was use the 96 harness with my 95 PCM and after having it tuned it worked out fine.
Old Jun 9, 2006 | 11:59 AM
  #32
stingercamaro's Avatar
I started looking for the dark blue fuel enable wire and it went to the black box (PN 16150920).
Shoebox, do you know where I can find one of those LT1 transplant bypass units.
DirtyDaveW
Dec 1, 2016 05:37 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
