No hole for pushrod....?
umm ok so i was out adjusting my rockers and i noticed on the driver side there is a little hole for the pushrod to go down into and you can't see the lifter at all. BUT on the passenger side there isn't! And you can see all the way down to the lifter.
Is this normal?
Is this normal?
yup. 1 sec
See how in the 2nd one you can see down to the lifter. and in the first one you have that guide material piece with a hole for the rod...
Other then that its making it hard trying to put this rod back in..
because now i can't get the pushrod to go far down enough to get the rocker on good enough to start threading the bolt.
