No hole for pushrod....?
Old Mar 22, 2008 | 01:01 PM
97BBlackZ's Avatar
umm ok so i was out adjusting my rockers and i noticed on the driver side there is a little hole for the pushrod to go down into and you can't see the lifter at all. BUT on the passenger side there isn't! And you can see all the way down to the lifter.
Is this normal?
Old Mar 22, 2008 | 01:12 PM
ss.slp.ls1's Avatar
Can you try to post up pics?
Old Mar 22, 2008 | 01:17 PM
97BBlackZ's Avatar
yup. 1 sec
See how in the 2nd one you can see down to the lifter. and in the first one you have that guide material piece with a hole for the rod...
Old Mar 22, 2008 | 01:19 PM
wrd1972's Avatar
Cant wait to see this.
Old Mar 22, 2008 | 01:31 PM
joeSS97's Avatar
I am thinking you are looking at the hole in the gasket? I cant see in the pics. Probably different head gaskets on each side.
Old Mar 22, 2008 | 01:32 PM
ss.slp.ls1's Avatar
The guide material in the first one is from your head gasket. I hope you didn't forget it on the second head?
Old Mar 22, 2008 | 01:36 PM
97BBlackZ's Avatar
yea that was what i was referring to. I'm just trying to make sure its ok that it ISN'T there.
Other then that its making it hard trying to put this rod back in..
because now i can't get the pushrod to go far down enough to get the rocker on good enough to start threading the bolt.
Old Mar 22, 2008 | 07:35 PM
ss.slp.ls1's Avatar
So is it different head gaskets, or no head gasket?
Old Mar 22, 2008 | 08:01 PM
97s10ondubs's Avatar
different gasket, if there wasnt a gasket you'd have serious problems
Old Mar 22, 2008 | 08:05 PM
ss.slp.ls1's Avatar
I reread his post, I thought he was assembling the motor.
Old Mar 22, 2008 | 08:24 PM
97BBlackZ's Avatar
Different head gasket.
I figured all head gasket would have those holes
Old Mar 22, 2008 | 08:49 PM
Felpros from a couple years ago didnt have them.
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
generaldave
Sep 25, 2015 06:48 PM
4586
Jul 31, 2015 06:03 PM
Boss002
Jul 24, 2015 10:47 AM
