No fuel pressure help pls
Old Sep 1, 2011 | 05:38 PM
JooneJune's Avatar
Still reading 0 psi to the rail.
Replaced
3 rail mount gauges all said 0.
2 fuel pressure regs one afpr one new oem
New fuel filter
Tried stock pump reads 3-5psi
Tried new unused 255 walbro 0psi
Yet both pumps prime fuel to the rail (I disconnected the feed line and saw fuel coming out)
What's the deal!?
Would a burnt opti send a signal to the PCM to stop fuel pressure from building?
Old Sep 1, 2011 | 05:39 PM
JooneJune's Avatar
Re: No fuel pressure help pls
I have a new 255 coming thus Saturday
Old Sep 2, 2011 | 05:24 AM
Are the fuel pressure gauges the "test" type that have a pin that depresses the core of the Schrader valve, or are they the permanent type that require that you remove the Schrader core before installing them?
Old Sep 2, 2011 | 01:48 PM
JooneJune's Avatar
All 3 we perm, the schrader is removed
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
