No Crank on my lt1 please help
Old May 13, 2009 | 12:51 PM
Angel_G_Z28's Avatar
I have a 94 lt1 z28 the car was having some spark issues earlier this week i tightend all the wiring and the car ran great for a day, on monday when i went to start it up in the morning the car wouldnt crank and the security light is flashing , anyone that can help me diagnose the problem please post up,
thanks,
Old May 13, 2009 | 12:57 PM
josh77888's Avatar
i had the same problem when i put my engine in, check the grounds for the wiring it caused it to no crank.
Old May 13, 2009 | 01:02 PM
bw_hunter's Avatar
The flashing security light indicates that the VAT system is engaged. It expects a key with a certain resistance or it won't allow the car to start. Anyway, as the key and lock cylindeer 'age' sometimes there are problems. If you have a spare key, try that. If you need more help after that, Shoebox's page can help: http://shbox.com/1/pass_key.html
Good luck!
Old May 13, 2009 | 05:27 PM
if the the key pellet were to lose contact while the car was running would this cause it to loose spark ?
Old May 14, 2009 | 12:48 PM
Ok so has anyone ever done the bypass on both the fuel cutoff and spark cutoff module cause from what iread on shbox i would rather just bypass all this nonsense since no one is stupid enough to try and steal my car. need a guide to do this id appreciate the help fellas
Old May 16, 2009 | 09:04 AM
Guest47904's Avatar
Guest
do the resistor bypass on the orange wrapped wire listed on his website.
Old May 16, 2009 | 10:09 AM
http://shbox.com/1/vats_bypass.jpg
Old May 16, 2009 | 10:13 AM
No. There is no spark cut-off. Additionally, nothing will happen while the engine is running, except that the security lamp will come on.
Anyone that has ever transplanted an LT1 into another body type has had to do this. Just follow the recommendations on the page.
Old May 24, 2009 | 12:13 PM
i havent had time to work on the car till today and when i got to it, it looks like some one had already tried messing with the vats system in this car so im kind of at a dead end unless i can get some under dash pics of an un tammpered vats module looks like.
Noer
Feb 28, 2015 11:29 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
