Nitto 555R 245/60/16
Old May 4, 2004 | 06:26 AM
  #16
1982z28with18s's Avatar
Please don't run more than 25psi in them on the streets if you want any decent life out of them. I've been through 4 pair of nittos, and I ran 32psi in the first pair and got several thousand miles less out of them. I now run 20psi in my 275/50/15's all the time and I drive 80 miles/day, and they wear out the middle some still, but not bad. The last 3 pairs I've got 14k+ out of all of them, and thats with some burnouts.
Old May 4, 2004 | 08:55 AM
  #17
aintno6's Avatar
14k w/ burnouts.... Sounds pretty good for a soft compound tire. I have them at 25psi now. I might drop them down some for thr track tonight.
TY,
Mike
Old May 4, 2004 | 10:24 AM
  #18
tfs95z28's Avatar
Most tracks wont even let you do a 15 second burn out...let alone launch it a little to see if you stick. Just do a burn out until you see some white smoke.
Ive got the same tires you are getting...granted my best 60 ft was only a 1.8, i know i can get better tho. Oh yeah, dont go thru the water...u dont need to with the nittos...
Old May 4, 2004 | 10:36 AM
  #19
GREGG 97Z's Avatar
The 555R everyones referring to is the other Nitto performance tire different from the drag radial correct? Just checking because I had Nitto DR's on my SS wheels I just sold, I'm looking for a new tire for the back for my 18x9.5 Y2K C5's that might see a little track use and was thinking of the 555R. Nitto dr's last about 10-15k, you guys are saying this 555R only makes it to 15K too?
Old May 4, 2004 | 10:52 AM
  #20
555r = nitto drag radials
Old May 4, 2004 | 11:30 AM
  #21
GREGG 97Z's Avatar
I usually refer to them as Nitto drag radials, not 555R's. Anyone running this other Nitto NT 555 tire? Just wondering how well they compare to the DR's I assume they would wear better.
Old May 4, 2004 | 02:31 PM
  #22
aintno6's Avatar
k well Im going to go ahead and get the tires wet. Since most of you have recommended it. And I was told that dry hopping isnt a good idea on soft compound tires.
Old May 4, 2004 | 03:05 PM
  #23
tfs95z28's Avatar
pretty sure you wont hop with a dry burnout...I know i havent. I wouldnt go thru the water if i were you. Just my $.02
Old May 5, 2004 | 12:24 AM
  #24
Nestromo's Avatar
20psi and even wear here.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
mrwz28
Jul 8, 2015 09:11 PM
ltlhomer
Aug 25, 2002 01:53 PM
