NGK or Autolite? Iridium or not?
Old Jan 12, 2006 | 12:17 AM
klpps's Avatar
I did some searches but wanted to get more definite answers.
I've decided on either NGK-TR6 or Autolite 103. Both are pretty cheap plugs. Is one DEFINATELY better than the other?
I've read that theres not a hp difference between regular and iridium but how much longer life can I really expect from the iridiums? Is it along the lines of 4 times longer life? That would then justify the 4x increase in price I guess. Any help would be awesome.
Old Jan 12, 2006 | 12:21 AM
imnotfast's Avatar
Re: NGK or Autolite? Iridium or not?
Was having problems with the autolite 103's hitting the hedder tube. they are about 1/4 longer. Been using TR-6 with hooker LT's
Old Jan 12, 2006 | 12:28 AM
1FstFormulaV8's Avatar
I've had some autolite's they lasted a good 2 days until they cracked. I used Bosh Plats with no success. I'm back to A/C Delco's now. Seems to be doing the job. I'll go with Iridiums when the time and money comes.
Old Jan 12, 2006 | 01:31 AM
Cmr0z28's Avatar
Ran TR6s a few times...they would get black spots all over, I don't know why. I'm now using Autolite 104s which are a little shorter, and after making 4-5 passes on N2O, they still look perfect.
Old Jan 12, 2006 | 06:01 AM
scottslt1z28's Avatar
I dont have any experience with Autolite, because i have always run NGK
However i will say this....get the copper ones..............you will have to change them more often, but copper is a better conuctor than iridium...
Old Jan 12, 2006 | 10:01 AM
klpps's Avatar
anyone know how longer iridium is supposed to last over the coppers?
Old Jan 12, 2006 | 12:54 PM
The Autolite 103 is two steps colder than stock. The TR6 is only one step colder than stock. The equivalent Autolite would be the 104.
I've run the Autolite 103 and 104 plugs with my nitrous applications (up to a 125-shot, or about 625 total HP) for 5 years with no problems. Also used the NGK TR6's with the bolt-on engine and a 125-shot for several years with no problems.
Slayer
Aug 17, 2015 03:55 PM
BMX Dad
Aug 15, 2015 01:15 PM
BLK1997Z28
May 7, 2015 03:01 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
blac94Z
Feb 23, 2015 04:29 PM
