!newb question, how to drain brake fluid?
Old May 18, 2003 | 09:19 AM
Kuma's Avatar
Question !newb question, how to drain brake fluid?
Installing rear brake pads, how do I drain "two thirds of the brake fluid from the master cylinder reservoir?"
Thanks in advance...
Old May 18, 2003 | 09:32 AM
1fast95Z's Avatar
I recently changed the front rotors and pads on mine and I used, strangely enough, a turkey baster to suck out the fluid (of course, never use the baster for anything else now )
Old May 18, 2003 | 10:13 AM
Whatever you do, be VERY careful with the brake fluid. It will destroy the paint instantaneously..... melt right through it. One drop and you will have a mess.
From my experience, pushing the 4th Gen pistons back in the calipers does not move a lot of fluid back into the reservoir. I've done it without removing any fluid.
But, you need to watch it carefully, because the fluid will ruin the paint whether you drip it out of a turkey baster, or blow it out of the reservoir.
Old May 18, 2003 | 01:50 PM
Kuma's Avatar
completed
Just got back in from changing the pads a little while ago. Went pretty smoothly, used a turkey baster to good effect. *Did* spill some brake fluid on the headers, then when I started up the engine I thought it was on fire, smelled so bad.
Squeek that was bugging me for weeks seems to be gone. However, I noticed that there still seemed to be a goodly thickness to the pads left, and that there was still a little ways to go before the wear indicators.
Could've been something else causing the squeek?
jb4xx
Feb 2, 2015 10:00 PM
Sandersen511
Jan 13, 2015 03:49 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
NAVY99
Jul 30, 2002 10:51 PM
