Newb question
Old Nov 16, 2011 | 05:55 PM
oneclean97z's Avatar
Newb question
So i have a cool air intake, aftermarket elbow, and throttle body air foil. Also cleaned out heads. I have a cutout before muffler. Question is should i get magnaflow high flow cats? (dual) car is 97. Or pacesetter mid tube headers? How would sound and power differ between the two choices?
Old Nov 16, 2011 | 06:52 PM
TeeTopZ's Avatar
Re: Newb question
From everything I have read, the mids for dual cat cars are poor designs. It seems most go with an earlier single cat setup if you really want mids. You could just get long tubes with an ORY and ditch the dual cats. Good luck and I am sure someone way more knowledgeable than I will chime in shortly
Old Nov 16, 2011 | 07:12 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: Newb question
I would go with longtubes.
Old Nov 16, 2011 | 09:07 PM
JGuy07's Avatar
Re: Newb question
Unless you need shorties or mid's and cats for emissions reasons why bother? Go with the LT's.
Old Nov 16, 2011 | 10:58 PM
Re: Newb question
yes i need to retain all stock emmisions. the pacesetter mids will do so. i got qouted for 5.5 hrs of work to install them. you guys think that's bullogna?
Old Nov 17, 2011 | 12:12 AM
kwik_ta's Avatar
Re: Newb question
I'll look up the labor rates tmo when i get to work. That seems a bit high but these cars are nightmares for certain repairs. Before you decide on headers, consider that even shorties provide benefits because of scavenging ability but offer little in the way of performance gains. You would get same or better gains by honing out the manifolds. Plus they don't blow gaskets like headers do.
Before you decide call the guys at exotic muscle. They might be able to fabricate a mid pipe with high flow cats to match a set of long tubes. Those guys kick ***
Old Nov 17, 2011 | 01:05 AM
Re: Newb question
right on. heard of the place. guess you used to live in houston lol? but yea, 5.5 hrs labor seems steep, seeing as how im told you can lift the motor to have room, then its a 1-2 hour job.
Old Nov 17, 2011 | 10:53 AM
kwik_ta's Avatar
Re: Newb question
According to Mitchell labor guide its 2.4 for the left and 3.8 for the right. Total 6.2 hours for complete install. This is quoted with traction control and electrical interference. Without is 6.0 hours. What was the total amount they were quoting for install?
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
