NEW TO SITE. 1993 lt1 into a 1995 z28?
I Have a 1995 z28 with a bad motor. I have a 1993 Z28 lt1 complete with computer. will this motor go into 1995 z28? I was thinking of putting the old computer in with engine.Do not know if this will work? also what transmission should I use. I have both autos.
Good luck!
Lots of differences between the 93's LT1/4L60/ECM setup, and the 95's LT1/4L60E/PCM setup. Your 95 4L60E needs the 95 PCM to shift it and lock up the torque converter. The 93 ECM will not shift it, or supply the pulse width modulated TC lockup signal.
93 runs speed-density (no MAF sensor) and batch-frie injection (compared to the 94-97 full sequential). Nothing you can't live with, but you need to be aware of the differences.
I personally would keep the 95's PCM, wiring harness and 4L60E, and swap over the critical parts of the engine from the 95 to the 93 - intake manifold and fuel rails/injectors, vented Opti with vacuum harness (which requires swapping the cam, timing set and timing cover), throttle body (93 will have TV cable for the manually non-electronic 4L60, and a different IAC vavle electrical connection), AIR and EGR plumbing.
Garcia5
Jul 7, 2022 06:51 PM
Jan 5, 2015 07:14 PM
