New opti only lasted overnight?
Old Feb 5, 2007 | 04:25 PM
  #16
formula-bird's Avatar
Originally Posted by 2tight
Man I'm sorry to here that, I know it's a pain in the a$$ to do all that work and then have to think about doing it again. If you read all the post on here I read alot of people get bad unit's , I read that one guy got 5 that were bad. I cant believe GM hasn't fix the problem. I'll keep in touch and let you know how mine goes. Did you do this on your 96 ?
Yes, it is on my 96. I'm just going to box it back up and send it back to summit and return it for anotherone.
Old Feb 5, 2007 | 08:51 PM
  #17
sbs's Avatar
sbs
Try diagnosing the problem before you send back what is probably a perfectly good optispark.
Yes, and i'm guessing that they are the ones in the black box on the drivers side fenderwell. All of them was fine.
Based on your two threads, it sounds like you're doing a lot of guessing...
Old Feb 5, 2007 | 09:11 PM
  #18
2tight's Avatar
So if I understand what your saying replacing a bad optispark could also cause other comonents it fail or be bad at the same time?
Old Feb 5, 2007 | 09:29 PM
  #19
95LT1conv's Avatar
double check both ends of the opti harness
Old Feb 5, 2007 | 09:36 PM
  #20
Yes i am. When the new opti was in it sat there and ran fine. And had a really snappy throttle. So when it would not start back up the next day, i tried 2 different icm's and coils and it was all the same, just would crank over. I've checked all of the fuses, plug wires and coil wire, and all of the connecters to the coil,opti,icm and every place else under the hood.
Old Feb 5, 2007 | 10:54 PM
  #21
Why did you start a second thread on the same subject? Not a good idea.
Merging threads.
Old Feb 5, 2007 | 11:03 PM
  #22
Merging threads.
I guess i just wasn't thinking. Thanks for using your Mod powers to merg them together.
Old Feb 5, 2007 | 11:22 PM
  #23
95LT1conv's Avatar
http://shbox.com/1/4th_gen_tech2.html#opti_test
have you tried this test yet?
Old Feb 5, 2007 | 11:33 PM
  #24
Originally Posted by 95LT1conv
Cool thanks, although the opti is in the box ready to go back and be replaced with another one. I talked with their tech support and they said it would be fine if i could return it for another one. If i have any proplems with it again with the another opti i'll try this test on it. I'm very thankful for all of your guy's help
Old Feb 14, 2007 | 09:19 PM
  #25
Ok, got the new opti in and still is doing the same thing. So i did this test http://shbox.com/1/4th_gen_tech2.html#opti_test and found 0v at A&D. But there is plunty of spark. It has a new opti, icm ,and a coil. All of the connections are clean can't find any broken wires. Checked all the fuses and they are all good. But there is a unmarked relay in the fuse box under the hood that is located in slot G. I can hear the full pump prime. And now my drivers side window won't go down. My dad segested that the car has a security system on it, that armed itself and won't let the car start or let the window go down. But i don't have a key flob with a security button on it, and i don't see a security device back by the spare tire were one should be mounted. There is a security light in the insterment cluster and a little red light on the trim that goes around the gauges, neither one is on. I'm at a loss to what is wrong with this car????
Old Feb 15, 2007 | 05:16 AM
  #26
Guest47904's Avatar
Guest
So if you have spark, the next thing to check is fuel. The easiest way to see if it's not getting fuel is squirt some in the intake while someone cranks it over. If you show a fuel problem, then check pressure and if that's good, check for injector pulses.
Old Mar 28, 2007 | 07:17 PM
  #27
spcearle's Avatar
did you ever find a solution on this...or the problem
Old Mar 28, 2007 | 10:07 PM
  #28
zlighting's Avatar
Make certain the opti-spark vent harness is plugged into the vacuum port of the intake manifold. (see shoebox’s photo)
Old Mar 29, 2007 | 04:54 AM
  #29
lt11997's Avatar
I wish people would update their theads and tell us what fixed the problem. I guess I got a little disappointed when I read through this and didn't find a the solution
Old Mar 29, 2007 | 07:51 AM
  #30
race24x's Avatar
I have to admit I was out of cars (worked for GM for 8 years) for about 10 years now and the Opti setup intimidated me at first. My W/P went drove the car in the garage and then after replacing W/P would not start. I had been to the site and read up about W/P replacement and how alot of Opti's failed from bad W/P so I bought one for my car. Blah blah still wouldnt run bought coil etc and so on getting really frustrated. Finally went back to basics. Check for spark at Opti if you have spark chances are its not the Opti coil etc its fuel related or fouled plugs something like that. In my case no spark so I checked for spark at coil still no spark checked for power to coil no power used a test light to check all fuses found bad fuse in fuse box under hood changed and started the car. Got to tell you it was very frustrating and took me like 3 weeks all together working on it after work and waiting for parts etc. Oh yah forgot to mention bought used Opti then a new one LMAO. Just pointing out dont overthink the problem I am still kicking myself in the ***. BTW anyone want or need a used Opti?
SteveRLz28
Mar 16, 2015 10:52 AM
ro2207
Dec 4, 2014 06:18 PM
yosshimura
Aug 12, 2002 06:47 AM
RichardZ SS
Aug 3, 2002 12:26 PM
STS-Formula
Jul 26, 2002 01:35 PM
