New Numbers
Old Oct 18, 2003 | 06:18 PM
kevinsz2895's Avatar
New Numbers
Guys i just perchased a 97 Z28 and put Moroso CAI and Flowmaster muffler and i have a 315 drag radial and i run at the local track
60ft -2.1 i was spinning with 315 at 11lbs 80 mph
1/4 13.80 104
is that good for a stock car with 17x11 on the back?? just wondering???
p.s. its a m6
Old Oct 18, 2003 | 07:16 PM
aintno6's Avatar
thats pretty decent for the mods you have. I would see if you could goto the track when it has better track prep, or if there is a better track. Cause I run 2.0 60ft with basic street tires. Did you heat them tires up really good?
Old Oct 18, 2003 | 07:19 PM
KeVMaN's Avatar
you can probably shave about 3 tenths off if you got a good launch. alot of peeps do 2.0 60' bone stock
Old Oct 19, 2003 | 01:22 AM
yeah i heated the tires up im hoping for a 1.9 60ft if so that will drop my et's to a 8.6 and 13.60 i cant complain with that on a mostly stock LT1
Old Oct 19, 2003 | 11:29 AM
Spinner's Avatar
Don't run DRs under 18 psi, you're just hurting your times. Under about 18 psi, they start to cup, and you wont get good contact with center tread (they will ride on the outer edge around the sidewall) and the increase in internal friction will slow your MPH down a bit
Boss002
Jan 20, 2016 12:17 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
Catmaigne
Jul 14, 2015 05:17 PM
gelbza
Jul 12, 2015 08:10 AM
