Bottomed out... Whats wrong??
Old Oct 19, 2003 | 09:21 AM
CoUnTryMuZiCZ28's Avatar
Unhappy Bottomed out... Whats wrong??
I was laid off at work for two weeks and I left kinda mad and i didnt see the big dip in the road and i flew over it and bottomed out the car.. I dont see anything wrong. i dont really feel anything wrong.. The glove box popped open and the raer view mirror readjusted itself pointing down... All i can see is the K-Member got scratched and the y-pipe is dented about half an inch.. also that stupid air dam is kinda scraped up....could I have damaged anything else... I cant see anything messed up.. ALSO----- is that bad that the y pipe is dented???------- Its the part that runs in front of the oil pan..
Old Oct 19, 2003 | 09:55 AM
NVetro's Avatar
well if you have the single cat setup, which I think you do. If it dented the Y pipe thats between the oil pan and trans, I would look closley at the oil pan and trans to check for damage. They are VERY close to each other.
Old Oct 19, 2003 | 10:17 AM
JPSartre12's Avatar
Re: Bottomed out... Whats wrong??
I've bottomed out mine a few times while getting used to the dropped front end. I've got a few scrapes on the airdam, header collectors and K-members but nothing serious. One scrape came at 60 mph after the road surface changed dramatically where the concrete met a newly tarred section. Now THAT sux!
Old Oct 19, 2003 | 11:36 AM
96 TA's Avatar
I went air born in my car doing some kinda Dukes of Hazzard stunt (not intentional) I bottomed out pretty good but my K-member took most of the brunt of the impact. Check to see if the headers hadn't loosened up. But if you feel no vibrations or hear anything then your alright.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
Z Power
Sep 19, 2015 11:19 PM
Formula Steve
Sep 19, 2015 08:48 PM
