new lt1 problems
Old Jun 15, 2010 | 07:44 PM
modelman1's Avatar
new lt1 problems
motor runs good but when it starts to warm up it wants to die.
Old Jun 15, 2010 | 09:59 PM
Something doesn't like the heat. Possibilities include:
-Accel Opti
-IC Module
-faulty coolant temp sensor
-faulty O2 sensors or wiring
Have you scanned it for codes? Do you have the software for a data log? Have you checked to see how the IAC counts respond to it when it "wants to die"? Does the deterioration correspond to the transition to closed loop?
Maybe its the "Pam forless" tune
Old Jun 15, 2010 | 10:52 PM
modelman1's Avatar
lt1 problems
all of these are new and i check everything that i can think it could be. any help or ideals would be great.thanks david
Accel Opti
IC Module
coolant temp sensor
O2 sensors and wiring
Old Jun 16, 2010 | 05:17 AM
The fact that a component is new does not eliminate the possibility that it isn't functioning properly or connected properly. The Accel Opti is a prime example - poor quality, based on numerous reports of problems with them.
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
