New LT1 harmonic damper from Jegs
Old Sep 26, 2006 | 03:12 PM
  #16
The Engineer's Avatar
Re: New LT1 harmonic damper from Jegs
Originally Posted by Eric Bazan
Can you use this hub with the stock dampner? Thanks, Eric
I have the Jeg's 10 percent underdrive SFI dampner and hub. I'm very happy with both, as they are high quality items.
Initally, I used the Jeg's dampner on my stock GM hub, then later added the Jeg's hub w/ woodrif key. The Jeg's machined hub is an udgrade over the stock casting three spoke. So, I would guess the stock dampner would also fit on the Jeg's hub.
WD
Old Sep 26, 2006 | 03:48 PM
  #17
Eric Bazan's Avatar
anyone have any pics of this set up?
Old Sep 27, 2006 | 01:16 PM
  #18
mzgp5x's Avatar
I purchased one for my 97. Very similar to the stock dampner, and, for internal balance assembly. Worked very nice with my D1 7.6" dia pulley. Had to machine a small pilot spacer. It fit the stock crank hub, and, I used a larger ARP dampner bolt (head collar). My experience is... it is difficult to engage a key on the crank when assembling the hub into the time case cover. Did not work well.
cyteone
Feb 7, 2015 06:04 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
