new heads...lots of measurements
Old May 31, 2009 | 11:10 AM
Gio93z's Avatar
I just ordered a set of AFR 1039 heads for my 93 camaro with a 383. I'm planning on running a 1.6 RR as well. One of the things that was recommended I do, is to go over valvetrain geometry and try and get the correct length pushrods. However, it looks as though I will also have to check my piston to valve clearance. My question is: will pushrod length affect piston to valve clearance? Because if it does, then which measurement should I try and do first? Is that an accurate question?
Thanks! Giovanni
Old May 31, 2009 | 12:59 PM
Stl94LT1's Avatar
No, the correct pushrod length will not affect PTV clearance.
Old May 31, 2009 | 01:59 PM
Gio93z's Avatar
alright im glad that is the case - thanks for the info
heus
Sep 8, 2015 12:01 PM
Aug 24, 2015 06:41 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Aug 7, 2015 01:26 PM
1ofmany
3rd Gen / L98 Engine Tech
Nov 28, 2002 07:12 PM
