New ecm now won't start 94 camaro
Old Apr 19, 2019 | 06:22 PM
Joseph Priest's Avatar
Put new ecm in car now. Now car won't start. Only starts with ether. And only for a few seconds.put new fuel pump in. And injectors, getting fuel to valve top of engine. Anyone?
Old Apr 19, 2019 | 10:10 PM
Re: New ecm now won't start 94 camaro
Why did you replace the PCM (last year for the ECM was 1993)? Did the engine start before you replaced it?
Why did you replace the fuel pump? Did you check the pressure before replacing it? What was/is the fuel pressure when the pump primes for 2 seconds, then shuts off? Have you scanned it for codes?
Do you have spark at the plugs? ...... at the coil wire?
Mortify
Apr 16, 2007 09:46 AM
dkeers
Apr 12, 2005 09:18 PM
zapper_zapper
Jun 11, 2004 07:37 AM
camaro9402
May 24, 2004 02:53 PM
redygo
May 29, 2003 05:05 AM
