New dyno numbers
Old May 25, 2004 | 03:29 PM
94YellowTAGT's Avatar
New dyno numbers
I was looking for the 300 mark but fell short.
295 rwhp and 328 rwtq
a/f ratio was 14 to 1
Weather was hot and humid
What do you think?
Old May 25, 2004 | 03:32 PM
Spinner's Avatar
Damn good for the mods you have
Old May 25, 2004 | 03:35 PM
The car also has 120K miles on it. I was happy but i will go back in better weather to get that 300 mark.
Old May 25, 2004 | 05:38 PM
Fastbird93's Avatar
You drop that A/F a point and you'll be there.
Old May 25, 2004 | 07:45 PM
stereomandan's Avatar
Holy crap! Great numbers.
Thanks for posting your numbers. I have a very similar setup, engine wise, and I thought there was more in it. Your numbers prove that. I'm happy with my numbers right now, but would be REALLY happy with your numbers.
Those are SAE numbers right?
My STD numbers were 289 rwhp / 322 rwtq
Dan
Old May 26, 2004 | 08:00 AM
they are SAE corrected
Old May 26, 2004 | 09:12 AM
LT1ponykilla's Avatar
Good stuff.
Old May 26, 2004 | 12:29 PM
Then "going back in better weather" isn't going to help.... that's what the correction factor takes care of.
Old May 26, 2004 | 12:32 PM
The dyno operator said it was just for elavation when i asked that question. I thought that it was corrected for temp and other conditions.
Old May 26, 2004 | 01:26 PM
"SAE" factor corrects the data to 29.23"Hg barometer, 77degF inlet air temp, and 0% humidity.
Old May 26, 2004 | 05:26 PM
Yeah, if it's only corrected for altitude somehow, then it's not corrected to SAE. How high of an altitude are you at? I'm not sure I can compare to your numbers anymore, because I'm at sea level, and no matter how you correct to higher altitudes, I'm not sure you would come up with the same numbers as you would at sea level.
What does the dyno chart say on it?
Good numbers though.
Dan
Old May 26, 2004 | 05:41 PM
truedualws6's Avatar
I would say those are very good numbers. And the SAE
correction takes care of everything, temp, pressure and
moisture content. It's what you call a level playing field.
Just as Injuneer said.
Old May 27, 2004 | 07:59 AM
I am not that high up in MO. It is SAE corrected.
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
BLK1997Z28
May 7, 2015 03:01 PM
racecarz28
Mar 30, 2015 09:55 PM
Joe Brodman
Jul 24, 2002 05:24 AM
