new crank hub
Old Nov 26, 2007 | 05:43 PM
thebufenator's Avatar
new crank hub
I need to buy a new crank hub for my 383.
Its keyed, and it needs to fit the stock damper design.
I was looking at the ATI keyed hubs, as they are not too expensive, and they have light weight aluminum ones.
Does anybody know which one will fit?
I ordered one from summit taht I thought would fit, but its got too large of a diameter where the hub fits over, so my hub wont fit.
please help!!
thanks
Buff
Old Nov 27, 2007 | 07:14 AM
Sounds like you need a keyed stock damper. Try Thunder Racing.... they may sell one. Or you can have your stock hub keyed. If you are building a high performance engine, why not upgrade to an SFI-rated damper, like the ATI?
Old Nov 27, 2007 | 08:18 AM
I did get a new damper, but it matches the old stock damper in the way it attaches.
is it worth it to get a key aluminum hub over the heavy stock one?
Old Nov 27, 2007 | 05:09 PM
When the weight is that close to the center of the crank, is makes very little difference.
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
