Does the melling 10554 select pump come with a high pressure spring?
Old Nov 26, 2007 | 04:17 PM
speed_demon24's Avatar
It came with a purple spring in it and it feels a little bit stiffer than my white GM spring. I'm not sure what one to use.
Old Nov 26, 2007 | 05:01 PM
Dave1980's Avatar
man I would call melling and ask them about that. They might even have another spring to use.
Old Nov 26, 2007 | 05:58 PM
sam pace's Avatar
Your pump is std volume std pressure with 3/4" inlet.
If I remember correct, pink is melling's high pressure spring.
Use the GM white spring if you want the higher oil pressure.
Old Nov 26, 2007 | 06:29 PM
Dave1980's Avatar
so they both do the same thing? Does one have more pressure than the other?
Old Nov 26, 2007 | 06:44 PM
FASTFATBOY's Avatar
Did you buy the pump new? In my Melling select box the instructions in the box said what spring did what. I think mine had a white spring in the pump and a purple in the box.
David
sam pace's Avatar
They both give you between about 60-70 running psi at cruising speed and about 50psi at idle.
With the current spring in the pump It would be about 30-40 psi idle and 40-50 psi cruising.
My select pump only came with 1 spring and hardend shaft.
Old Nov 26, 2007 | 08:59 PM
It's not very scientific but I put both springs on a screw driver with washers sepearting them, and the white spring was always taller than the one from melling, so the white spring is stiffer and will have higher oil pressure.
Old Nov 27, 2007 | 05:30 PM
sam pace's Avatar
Yes
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 23, 2015 01:13 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
