new cam timing
Old Apr 30, 2004 | 09:20 PM
TrouserSnake's Avatar
Arrow new cam timing
ok Do I have to take the opti apart on a 94 lt1 set the number 1 at TDC and move the rotor to spark plug number one?
If so off with the harmonic balancer pulley
I wish maybe just one person who did there ****ty write up would of added this step into the cam install guide..
Old Apr 30, 2004 | 09:48 PM
hmmmp no-body aye.....
I should have asked whats a good cat back.... I would have got stormed with people who have done cam installs
Old Apr 30, 2004 | 10:25 PM
You know, I had a technical response typed in, but I erased it. As a person that has a cam install guide on my site, I take offense at your remarks. Taking the opti apart should not be a step in any procedure unless you screwed something up by not following directions.
Good luck in figuring it out. With your attitude, you are going to need it.
Old Apr 30, 2004 | 10:27 PM
Robs97Z28's Avatar
WHATEVER.....DUDE! GOOD LUCK! LOL
Old May 1, 2004 | 09:34 AM
Shoebox I looked everywhere for a decent cam install site.. I had no Idea you did a right up...
I was pretty pissed off after spending 4 hours getting the harmonic balancer off and already having it back
you Did a great write up
But wait a second... Everyone told me when the 2 dots where lined up correctally the the little dot should be directally above the small dot.. In picture TDC #6 Was I sopposed to put the timming chain back on when It was #1? Ive seen 4 or 5 right ups and it says that the #6 was TDC #1 and thats how it should be installed
Old May 1, 2004 | 09:35 AM
like this illistration http://shbox.com/1/cam_timing_ani.gif
Old May 1, 2004 | 09:54 AM
BTW my opti Is gear driven it isnt driven by the dowel..
so thats why I was asking if I would have to take it apart
Old May 1, 2004 | 09:56 AM
If you are saying that some LT1 write-ups that you have seen say the dots together are #1 TDC, they are incorrect.
The illustration is correct. If you lined up the dots together (#6 TDC), it should be on right. If you have a splined drive opti, you need to index it correctly when you install it. Line up the "missing" tooth.
Old May 1, 2004 | 10:14 AM
do you have AIM or Yahoo? I have some questions that need to be answered
Old May 1, 2004 | 10:41 AM
When I put it on I had to kinda turn it for that little key looking thing to line up.... you think I should be ok?
Old May 1, 2004 | 11:59 AM
TTT
Old May 1, 2004 | 12:06 PM
Yeah, that is what I was referring to lining up. That sounds good.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
