new bolt on Personal Best
Old Apr 9, 2008 | 03:48 PM
86formula's Avatar
12.60 @109mph
1.86 60'
brought the RPMs up on my last run rather then flashing it and it responded well but the trans slipped on the 2-3 shift. looks like its time for a rebuild. if the trans didnt slip im sure i wouldve went .5x
Old Apr 9, 2008 | 03:53 PM
GreasyB's Avatar
Good times you got there.
Old Apr 9, 2008 | 05:12 PM
MeanGreen97Z's Avatar
What kind of converter do you have? Go with CPT on the transmission rebuild. You wont regret it.
Old Apr 9, 2008 | 05:14 PM
86formula's Avatar
stock converter still. i take my stuff to JSPerformance and let him send it out, he puts out alot of good work
Old Apr 9, 2008 | 09:52 PM
2000GTP's Avatar
Very good times, especially on a stock converter. You still have some more gains to be had by changing that out.
Old Apr 9, 2008 | 09:55 PM
86formula's Avatar
thank you and oh i know im doing things one step at a time and seeing where my weak points are now. for example im having a little bit of wheel hop now so i need to change the shocks, if i were to throw a converter in there it would just be worse so im gonna fix things as i find them.
Old Apr 9, 2008 | 10:17 PM
3DFORMULA's Avatar
Good times, I like seeing the minimum mod cars, as mine is also, doing very good.
Old Apr 9, 2008 | 10:23 PM
1996camaroSSclone's Avatar
Nice time, that gives me a little hope for my 94 firebird with a few more mods.
Old Apr 9, 2008 | 10:52 PM
86formula's Avatar
i think im pretty close to LS1 bolt on times. makes me happy to know i can run side by side with most of them at the track.
Old Apr 9, 2008 | 11:06 PM
My goal is to beat a local LS1 running 7.81 fastest time in the 1/8th. I ran 8.75 with my camaro with 3.23 gears, A4, k&n cai and jet stage 2 pcm chip.
Old Apr 10, 2008 | 07:34 AM
SNOTGREEN's Avatar
Good times and especially your MPH. Which do you think was more beneficial to that, those roller rockers or your true duals setup?
Old Apr 10, 2008 | 10:01 AM
86formula's Avatar
i actually picked up .3 when i put on long tubes/trueduals and did a little weight reduction, RRs didnt do too much. just remember though if you do true duals you cant run a chassis mount torque arm unless you get the relocation kit (not cheap) and a stock length torque arm. you also save some weight with the duals over a traditional catback.
Victor Lamb
Aug 26, 2017 02:52 PM
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
sseeya
Apr 9, 2015 06:38 AM
maybe2fast
Mar 16, 2015 09:45 AM
